I did not find a module for dividing two complex numbers in AWE Designer. Do you have some solution for this as trying multiplying both sides by the conjugate of the denominator does not lead to a situation where I could feed these to AWE's Divide module?
Regards,
Mike
6:38pm
Hello Mike,
There is a complex divide module in the 'Frequency Domain > Math' path. You can also search 'complex', 'divide', or 'complex divide' in the module search bar to find the module. If you still don't see the module for some reason, please upgrade to the latest version of Audio Weaver (8.C.1.2) here: https://w.dspconcepts.com/downloads.
11:59am
Thanks Kevin. I was able to find it only after updating to 8.C.1.2. And even then I noticed that at some point Complex Divide module was with red circle in my design and I was not able to find it again. After restarting AWE Designer it was again visible and not with red circle.
Regards,
Mike
12:29pm
Hi Mike,
Glad you were able to find and use the module!
