Hello DSPC
I am considering running AWECoreOS on a Linux kernel.
I read in the Integration Guide that the multi-rate layout is broken down into sublayouts.
That means it can be shared by multiple CPUs as multiple PumpThreads, right?
Is there a way to do the same for single rate layouts, with multiple PumpThreads sharing the processing?
Thanks Naomichi
How to split threads for single rate layouts
          #1
1:07am
Hello naomichi_tsuduno_9939,
Your understanding about multi-rate AWE layouts and AWE "sublayout" terminology is 100% accurate. For additional information about AWE Linux process/thread affinity, please refer to this excerpt on our Documentation Hub: https://w.dspconcepts.com/hubfs/Docs-AWECoreOS/AWECoreOS_UserGuide/index....
Let us please continue this discussion via email (I will contact you, shortly) as it would be beneficial to discuss (potentially confidential) project and/or use-case details, in order for us to best support your inquiry and needs most efficiently.
