I have installed AWE Designer 8.D.2.6 on my PC; See details below:
Device name    NucBox_M5
Processor    AMD Ryzen 7 5700U with Radeon Graphics            1.80 GHz
Installed RAM    32.0 GB (31.4 GB usable)
Device ID    53BD51D2-D8F4-4F27-9081-8A04E29D32DB
Product ID    00330-54390-47374-AAOEM
System type    64-bit operating system, x64-based processor
Pen and touch    No pen or touch input is available for this display
When I try to run, AWE consistently claims its out of memory. It still launch, but the designer itself can not connect to it (see attached screen shot)
Also attached the server window.
It is obvious that I have plenty of memory. I can run the full Visual Studio without any issue...
2:36pm
Hello Yair,
Can you please also send the error message while you are running the awd? I see that you are a Pro user, does MATLAB also display the same error?
Best regards,
Karishma
2:41pm
Hi Yair,
We have seen this sometimes when using Windows Remote Desktop. Does that apply here? If so, try disabling Audio Forwarding in Remote Desktop.
Another thing you might wish to check is whether any "awe_designer.exe" process remains in the Windows Task Manager after shutting everything down. If so, use "End Task" to kill it.
Do either of these suggestions help?
2:50pm
Yes, I was using Remote Desktop. I'll try disable audio Forward.
