I don't know if it's just me, but I tried to run regression test from Designer with a simple AEC example and it has been running for over 3 hours.
- I'm testing on Native mode
- I know that it's not frozen because I am able to "Pause" it in Matlab and see that it's processing.
- If I run "test_sb_aec_v1.m", the test runs very fast.
- My Designer is "8.B.1.4.E-build382"
I've attached a screen shot of the system.
4:49pm
Hello CL,
I tried this in "8.B.1.4.E-build382 Pro", as well as our most current version "8.B.1.5-build467 Pro" and am noticing the same issues. Before I escalate, could you please let me know what you are seeing in your Matlab Console? (Screenshot or .txt).
4:51pm
I just see a continuous stream of text saying "regression failure, SNR ~48dB" or something along those lines. I won't have time to reproduce it right now but that's all that I see in the Matlab Console.
4:54pm
Hi CL,
Ok thanks, that's more or less the same thing as I'm seeing. Hope to have an update on it soon.
