Any insights on why I get the error in the picture enclosed? There seems to be a fractional difference in SR between Pin1 and 2, but both inputs have the same sampling rate. Note that I run into the same problem with a 48-kHz sampling rate.
I am running AWE 8.B.1.4.B
3:30pm
Hello Pablo,
Could you please attach the AWD, or at least the problematic portion of it here so we can troubleshoot? If you'd rather not publicly post it here, you can email me at Kkluka@dspconcepts.com.
9:21pm
Hello Kevin,
I am running into the same issue with the latest available version 8.C.1.3. I have enclosed the AWD file.
10:38pm
Hi Pablo,
Thanks for sharing your issue again, and my apologies for any inconveniences this may be causing you.
I'm actually able to run the exact design in multiple versions of Audio Weaver.
If I may ask, could you please provide some additional information for me?
In AWE Designer's top toolbar, if you navigate to 'Layout > Layout Properties', could you please let me know what source you are using? Is it 'Line Input' or 'File'?
Also, are you running in Native mode? (AWE Server will tell you - Native mode would be running on your PC).
12:01pm
Hi Kevin,
I am running the server in native mode, and I am using File input but changing it to Line input did not make a difference. The MATLAB version is 2021a. I am also running with an offline license since I always have troubles connecting to the license server. The enclosed picture shows an even worst case in which I am using exactly the same signal and still get a sampling rate mismatch. For both an interleave block and an adder block.
What multiple versions did you try?
Pablo
12:10pm
Hello Pablo,
I tried using 8.C.1.3 Standard, and a couple of internal repo builds of AWE Pro. As you can see, I have no issue running the exact .awd you provided:
Sorry for your troubles again, this is very strange.
If you go to 'AWE Server > File > Preferences', could you please let me know what sound cards you are using for your I/O? There could be a sampling error with the sound cards you are using?
1:56pm
Thanks for your reply Kevin but I do not think this is an audio card issue. I am using an RME babyface PRO and even when I am not using a SYS_in connection I get the problem. You can see the problem persists even for an AWE internal source (1-ch pink noise set to 48kHz). I am going to uninstall and install AWE again. I agree this is a very strange issue.
Thanks, Pablo.
3:10pm
Hello Pablo,
I see, make sense. This is one of those tricky things where I cannot reproduce the issue, so it may be hard to diagnose. Please let me know if the uninstall/re-install works.
If not, I will ask around internally if anyone has ever seen this.
Appreciate your patience with the issue.
