We have created a custom module using the Audio Weaver Pro software which can execute successfully using the Pro Designer.
However when we are trying to export that custom module and load it into the Standard Audio Weaver Designer we get the following error when dragging it into the layout:
"Audio Weaver Error
Adding module failed: Error using feval
Previously accessible file 'C:\DSP Concepts\AWE Designer 8.D.1.3 Standard\AWEModules\Source\Custom\matlab\custom_awe_module.m' is now inaccessible."
11:25am
Hello Joel,
In order to bring the custom module into Audio Weaver Designer Standard, you must turn it into an Interpreted Module. Please try following the App Note attached to do so. If you still have trouble, let's troubleshoot offline. Please feel free to email me at kkluka@dspconcepts.com.
7:53am
Hi Kevin,
Setting the interpreted module option solved it, thanks!
2:13pm
Great, thanks for letting us know Joel!
-Kevin
