Due to the way that the Standard edition of Designer is built using a MATLAB compiler, it is not currently possible to share your custom modules with folks who do not have the Pro edition of Designer.
I've been going through your example custom modules, created the custom modules which I can see in the Pro Edition but not in the Standard edition (even though AWE Server shows the module DLL, it doesn't show up if I search for it using the Module Palette).
Yes unfortunately this is still true. If you create a Custom Module, you will only be able to share it with people who also have Audio Weaver Pro. This may change in the future, but for now that is the only option for sharing Custom Modules.
10:08am
Hi Darrel,
6:33am
Is the above still the case ?
10:59am
Hello David,
