I am using a RME audio interface. It is the Fireface UFX II.
This interface runs well on 48/96/192kHz sample rates, on external applications. However, when I try to use it with AWE, the server outputs an error on 192kHz:
Starting audio failed
Failed,to open output sound card. Error = -1
The Native Audio Configuration is set on the Server. We also set the source as Line Input in the Layout properties.
But still, we cannot run AWE with the interface in 192kHz. I am attaching the patch we are using for this test.
Could you give me any direction on this issue?
9:13am
Hello Rodrigo,
192kHz shouldn't be a problem for Audio Weaver. In the AWE Server Native Audio Settings, which driver are you using? Could you try others to see if that resolves the issue?
11:35am
Hi Kevin,
Thanks for this quick reply.
We are using Asio drivers. I managed to make it work today, choosing a bigger buffer size. Maybe there are some limits in the USB communication between the interface/computer and the server. Anyways, we will do more testing here and update this thread if we find some other issue.
Best,
Rodrigo
12:17pm
Hello Rodrigo,
Great that you were able to make it work. I will follow up internally about the observed behavior.
