Can I use the MATLAB API to redesign a system that was loaded from a *.awd file?
By redesign I mainly mean changing the Argument values of some inner modules. For example, changing the numOut argument value of a Deinterleave module from 2 to 3.
Sharon.
5:23pm
Hi Sharon,
Some variables are hidden by default in MATLAB, but you can type the text below to view these.
Then if you'd like to change a variable such as the numOut of a deinterleave you can set that then run or export the design from MATLAB. The API guide in the docs folder of your download uses the example of a Scaler's gain range on page 9 - 11:
Then you can change the gain range by typing:
Then you can save to disk with:
Hope this helps. -Kyle
