How one can locate a MATLAB added new module in AWE Designer.
I've loaded a .awd file to MATLAB. Added a new module. Saved the new system to a new .awd file.
When I open the new file in AWE Designer, I can't locate the new added module. Only the modules that were added in AWE Designer are visible.
When I load the new .awd file back to MATLAB, I can see my added module.
What do I need to do in order for it to show up in the designer for future design changes?
Sharon.
5:29pm
Hi Sharon,
Have you added the module's path in Designer? You can do so by going File -> Set Module Path and adding a directory for your module.
You can also check if Designer has it in its path by going to the Server window and selecting Target -> List Modules.
