Do you have any solution to export tuning parameters from Audio Weaver Designer?
I am designing an automotive amplifier running with AWE Core and considering how AWE can read the tuned parameters from an external flash drive.
Keeping design files (.awd) on the external drive is not practical due to data size.
I would like to specify multiple modules and export their parameters to one CSV file.
(It's something like exporting parameters of BIquadSparseV6_1, BSV6_2, BSV6_3, ScalerV2_1, ScalerV2_2, Delay_1 and Delay2.)
Please let me know if my question is not clear enough for you.
Thank you for your support in advance.
Kind regards,
Satoshi.
2:43pm
Hello Satoshi,
I'm sorry, I'm not sure if you are talking about importing or exporting tuning parameters from Audio Weaver Designer. Could you please clarify?
Additionally, are you targeting specific module parameters you'd like to import/export or are you speaking in "general terms"?
Lastly, if you are able to share your use case for the parameter export/import, we may be able to give you better guidance.
5:52am
Hi Kevin,
Thank you for your reply, and I'm sorry for making you confused.
Let me clarify my question a bit more with a figure.
I would like to EXPORT or EXTRACT tunable parameters surrounded by red rectangles in the attached layout.
These parameters will be stored in a serial FLASH and be loaded from it when starting AWE Core on the target.
One method should be to extract the required commands from AWB.
It would be best if only the parameters could be exported as a CSV table.
Please let me know if you still have any questions.
Best regards,
Satoshi.
4:17pm
Hello Satoshi,
You can extract parameters from the Biquad Sparse module in its module properties (please see the attached photos), however the parameters are automatically stored in the AWD/AWB when saved in Audio Weaver Designer and thus persist when loading on target.
