The help for sub-band smoother is confusing - could someone please clarify?
The module supports two different forms of smoothing. In linear smoothing (type = 0), N bins to the left and N bins to the right of each bin are averaged, where N is a fixed number. The number of bins N is specified by the parameter .width, and .width is specified in Hz. If a bin is centered at frequency F, then the bins in the range [F-width F+width] are averaged.
Which is it? Is width "the number of bins N" (an integer)? or is it a frequency range ("specified in Hz")?
Thanks!
3:04pm
Hi Matt,
The user specifies the width as a float value representing the +/- frequency range to include. The number of bins (an int) is derived from this value.
