I want to set an argument with a drop down menu. I can see this is done in for example Biquad Sparse V6.
I could not find documentation on any fields of the argument. For a variable, I found the following way:
value_range = [0 1];
value_list = 'val1=0 val2=1';
add_variable(M, 'my_var', 'int', 0, 'parameter', 'Set my_var.');
M.my_var.range=value_range ;
M.my_var.isRangeEditable=0;
M.my_var.isHidden=0;
M.my_var.guiInfo.controlType='droplist';
M.my_var.guiInfo.nameValueList=value_list;
But I need this for an argument, so I tried it like this:
value_list = 'enum val1=0,val2=1';
add_argument(M, 'MY_VAR', value_list , 0, 'const', 'Comment.')
This gives me the drop down for the argument, but when I switch to val2 in the dropwdown,
I get the following error:
ERROR: Event handler returned an error.
Error stored in AWE_INFO.designer.lastComErr. Type:
rethrow(AWE_INFO.designer.lastComErr)
to examine the error in detail.
Summary Message: This data type is not yet handled File: target_number_to_string
Line: 0
Unable to resolve the name 'AWE_INFO.designer.lastComErr'.
What can I do?
11:54am
Here's the code that handles the filter type in BiquadSparseV6.
3:25am
Hi Gary, could you share the code for biquadForm in Biquad Sparse V6 please? I want to set a single value, not an array.
1:52pm
Here you go.
4:34am
Thank you very much. This would be very helpful to see in the documentation or in an example. I also wonder why the syntax is not the same as for a variable.
