According to the STM32F746G data sheet, the codec does support up to 96 KHz sampling rate. If you're going to be using 24-bit depth, then make sure to update the audio code to correctly translate it into the fract32 before pumping it into Audio Weaver. See this post for info on that: https://dspconcepts.com/forums/awe-core/436-distorted-sound-fir-filter
1:29pm
Hi Simon,
