High
I am trying to update my custom BSP for the ADS21489 SHARC DSP but the version is incompatible with the new V7.A.0.7 Designer.
I have downloaded the 1.2 BSP for the EZKit but I noticed the AWEInclude and AWELibs directories are missing so I copied across the old ones from 1.1 BSP that I have. The only problem is the version still reports V5 and the V7 designer is not compatible with this. How to upgrade to the latest version ?
Regards
David
1:27pm
Hi David,
If you use the binary straight from the v1.2 website download (without your custom code), are you able to run layouts?
9:55pm
Our hardware is different to the EZ kit so most likely it won't run with the standard code.
The last BSP build that you supplied to me contained the additional library files so I guess this is where the version info comes from.
Regards
David
9:12am
Hi Andrew
Any further info on the latest BSP otherwise my customers cannot use the latest Audioweaver Designer ?
regards
David
10:04am
Hi David,
We're looking into this - for now please keep using the older versions of Designer if possible. They are available for download here: https://dspconcepts.com/legacy-downloads
8:44pm
Will do.
Thanks Axel.
Regards
David
