After install, licensed, and apply proxy setting, I could open AWE Server like this.
after few seconds, an error message pop up.
Error connecting to the AWE Server. Verify that the Server is connected to the target.
Error in => awe_designer.m at line 127
When I launch "C:\DSP Concepts\AWE Designer 8.B.1.4.E-build382 Standard\Bin\win32-vc100-rel\AWE_Server.exe" only, there is no problem.
So, I think there is no problem in AWE_Server.
I also do "two executables need to be added to the firewall's exceptions list" stated in
https://dspconcepts.com/forums/audio-weaver-designer/61-cannot-launch-audio-weaver-designer
but, it does not effect.
please help me.
version : 8.B.1.4.E-build382
Windows 10 Enterprise
Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz 3.19 GHz
RAM : 16GB
64bit, x64 based processor
10:27am
Hello Hosten,
Could you please try making sure you have an input device (microphone) connected to your computer/ enabled? The issue you could be experiencing may be the same described in this forum post: https://dspconcepts.com/forums/awe-designer/712-failing-launch-gui-designer. Based on the screenshot of your Server window, it looks like you have '0 inputs' available. Please let me know if this fixes the issue.
7:35pm
Thank you Kevin
It works after set a microphone!!
7:54pm
Hi Hosten,
No problem, I'm glad it works now.
