Hello DSPC team,
I am using the Audio Weaver Designer 6.17.06 Standard edition in Windows 10 and am experiencing a problem when using the StatusSet module. According to the documentation an integer is required as input, however, it does not seem to work.
The following image shows a minimal example and the error message that occurs when pressing Run. I am using the Native target.
I look forward to your reply.
Regards,
Markus
9:17am
Hi Markus,
Thanks for reporting the error you found. We are aware that the StatusSet module is broken in 6.17.06, and we have implemented a fix to the module for the next release. Unfortunately, there is no work-around for the problem with the module.
Sorry for the inconvenience,
9:52am
Hi Axel,
thanks for your reply. When can I approximately expect the next release to be available? Or how long does it usually take for the next version to be released?
Regards,
Markus
10:39am
Hey Markus,
We don't have a release date yet, but it is likely that we create one more release by the end of the year.
