Hi Guys
My STM32F769 Discovery Board arrive today. I am very excited. But before I do anything, I would like to check with the experts, (I am nowhere near good at this and learning) ….
What accessories do I need? (Cords, PSU, SD Card….) There are a lot of connection possibilities, but I have NO, repeat Nothing that will connect to the board.
I would like to make a 3-way Audio Speaker Crossover with DSP. Not sure if there is any help there, but I am crossing fingers.
I am guessing I will probably be the only one with such a board in the NSW Country…. I know there are nothing like this in my town.
Thank you
D
11:28am
Hello! To get started, you will need two micro-usb cables that are preferably short in length. Also, they must not be charge-only cables! Some cheap-o USB cables that come with consumer electronics are charge only, meaning that they are not equipped to pass data, only power.
4:59pm
Hi Andrew
Thank you. Good point....
https://www.ebay.com.au/itm/New-1M-2M-3M-Micro-USB-Charger-Charging-Sync...
It states it is both charging and data. It is the old type not USBC...OK??
Micro USB Charger Charging Sync Data Cable for Smart Phones N4U8 01
Thank you
D
11:06am
Yes, that cable will work.
-Andrew
