Not much more to the question really. I'm dragging the ST modules into Designer but get an error saying 'Module class does not exist on the current target'. I assume this is because I am using the Windows native target but I need a board. Am I right in saying that I can use this board to run these modules? Is there a cheaper version that will do the same thing?
https://uk.farnell.com/stmicroelectronics/stm32f769i-eval/evaluation-boa...
11:14am
Hi Richard, what version of Designer are you running?
Here are some less expensive boards from Digikey:
https://www.digikey.com/en/products/detail/stmicroelectronics/STM32F769I...
https://www.digikey.com/short/4r2035v1
2:45pm
Thanks Kyle - I'm just using the free version (ST). I'm not sure if I can get Digikey from the UK.
2:58pm
Hi Richard,
To use the ST modules with Audio Weaver ST included in our publicly available BSP, as you guessed, you'll need to be in target mode with the supported SoCs listed at w.dspconcepts.com/downloads. If you require usage of the ST modules in a different BSP or in native mode, please contact sales@dspconcepts.com and we can look at possible configurations.
As for the board you use, on the UK website you linked, I found this less expensive ST32F69i discovery board which will work with Audio Weaver Core ST:
https://uk.farnell.com/stmicroelectronics/stm32f769i-disco/discovery-boa...
Hope that helps! Let me know if I can be of further assistance.
-Kyle
