I investigate some projects from "example" folder, for example "GuitarDistortion_fir_upsample.awd" and find some modules as AGCMultiplier, but I cannot find this module in modules list from left side of screen. But I still able to run this example and everything is work on native connection. And the same with many other modules. Why this modules works but I can not find it in module list?
Thanks!
9:51am
Thanks for the question. The reason that you cannot find certain modules in the module browser is because they have been deprecated. Some of the example designs were made a while back so they were designed while the deprecated modules were still current.
In order to maintain backwards compatibility, we still ship Designer with a deprecated module pack but they are hidden in the module browser by default. To change this, go to File->Global Preferences, and check the 'Show deprecated modules' box under the Module Browser section. You should now see the AGCMultiplier module listed in the module browser with a '(deprecated)' tag next to its name.
I hope this helps
