I am using Audioweaver ST edition, is it possible to use the designer without using the hardware, just using laptop and listening the result (not ST algorithm for ex equalizer) in headphone ?
Yes, you can use Designer in Windows by running the Server in Native mode. You can set up the desired audio input/output in File -> Preferences using the Audio Weaver Server.
9:25am
Hi etoz,
Enjoy
2:57am
Axel thank you for your reply I will test it out. And i have to add this is a great feature to play around with audio weaver.
Best Regards,
edit: Tested the feature it works greats.
