Hi
The point and auto connect feature for connecting blocks works well but sometimes the end result looks confusing with wires on top of each other and shorted out when they are not. If I try to separate the wires I can't seem to move them. Is there away of doing this ?
regards
david
12:13pm
Hey David,
Good question. When a design gets more complex the autoconnect algorithm doesn't always create a clean looking wiring map. To manually fix this, the marker module is typically used to redirect wires and create a neater looking design. Just insert a marker module in the offending wire's path and move the marker where you like the path to be redirected.
1:41pm
tip: right-click the canvas and select 'Add Marker'
