in some Audio Weaver Session I use Feedback Wires. In the Feedback Wire Properties I change the settings of numChannel, dataType etc. and also the clockDivider to value 1.
After running the session there's a mismatch between the clockDivider at the input Pins of e.g. an Add Module, where the feedback Wire and the feedforward wire should be join together. I checked several times the change of the clockDivider value by reopen the propertie window, but while running the session the value is again resetted to 0 and the Error window with the hint of the mismatch rises again.
So what is the ominous clockDivider (I cannot find anything in the manuals) and how can I solve my problem?
I think the default value of the clockDivider is 1, but my feedback wire doesn't accept this ;)
Thank You
Max
9:30am
Max,
You currently must set the clock divider to match the clock divider on the other wires. It was an oversight on our part to not make clock divider inheritable like the other properties of the feedback wire. Future versions of Designer will have inheritable clock divider.
