Following the instructions in AWE MATLAB API, I have set up my MATLAB path to include C:\DSP Concepts\Audio Weaver 6.17.06 Pro\matlab and all the sub-directories. However, for some reason the directory @awe_modules is not included and therefore I dont have access to functions like add_module and the like. Any ideas how can I solve this?
Pablo F. Hoffmann
4:39pm
Hi Pablo,
Adding the 'matlab' directory to the MATLAB path should be sufficient to use the AudioWeaver MATLAB API. Have you launched the AWE_Server in MATLAB before trying the commands? 'awe_init' or 'awe_designer' will both launch the Server.
If you type 'which add_module' in MATLAB it should report the @awe_module directory as the location of the function. As a test, does the following sequence of commands work for you in 6.17.06 Designer Pro? It should create a simple system with a scaler and meter, and then draw a crude representation of it in a MATLAB figure.
% Create system
SYS = target_system('Scaler Test System');
% Add pins and test modules
add_pin(SYS,'input', 'in', '' ,new_pin_type(2, 32, 48000, 'float'));
add_pin(SYS,'output', 'out', '', new_pin_type(2, 32, 48000, 'float'));
add_module(SYS, scaler_module('ScalerTest'));
add_module(SYS, meter_module('ScalerOutMeter'));
% Connect system
connect(SYS, '', 'ScalerTest');
connect(SYS, 'ScalerTest', '');
connect(SYS, 'ScalerTest', 'ScalerOutMeter');
% Build and print SYS
build(SYS);
draw(SYS);
5:25pm
Hi Axel,
Thank you for your reply.
As you can see from the picture the path is set, the "which" command works, but for some reason I cannot run the commands in @awe_module. I am puzzled.
Pablo
5:30pm
Hi Axel,
I looks like my way of testing was wrong. If I run any of the modules in @awe_module alone, as in the picture above, then I get the error message, but if run them including input parameters, like in your test script, then it works.
We are back on track. Thanks for your help.
KR, Pablo
5:35pm
Good to hear you figured it out!
