I'm using the above board as mentioned and it works great with the 3.5mm lineout, using my own audioweaver design.
I'd like to also send the output back to my laptop via USB to be able to record the output, but I don't seem to be able to change my output pins etc.
is this possible using AWEcore 8.B.5.1?
thanks
11:06am
Using the STM32F769I, the right output pin ‘SYS_out’ has four channels of output. The first two are the audio being output to the line-out connector and the last two are USB record.
When connected to your PC, your board should appear as a USB audio device. You can select this as your input device for recording the USB audio output from the board.
Michael
