I have some questions concerning your threading model described in your Integration Guide on page 20 and 21. Can those 4 or more threads run simultaneously, i.e. in a multithreading application on a multi-core processor? Or do they have to follow the described schedule as shown in the figure below (which has been extracted from the Integration Guide)?
If the threads cannot run simultaneously, can they be interrupted and continued at any time, e.g. as it might be in multithreading single-core applications the case? According to the figure, at least the audio processing thread can be interrupted.
Regards,
Markus
9:57am
In short, Yes. It's intended for multi-threaded environments.
That image shows all the threads simultaneously active, with each thread having a different priority. The "Audio I/O" thread is the highest priority. After the first Audio interrupt in this image, both processing treads were activated. The 32-sample block [green] thread runs first because it's higher priority. When it completes, the 64-sample thread [blue] begins to run - but the processing in this thread takes a while to execute, so it doesn't complete before it's interrupted again.
After the second Audio interrupt, the 32-sample processing runs. When that completes, priority returns to the in-process 64-sample thread, which then completes, and execution falls to the background thread. This cycle repeats every 2nd interrupt.
10:29am
Thanks for your answer. So as I understand it, the AWE core library is or should be thread-safe. Only the priorities have to be kept in mind.
