I had Audio Weaver Designer ST Edition installed and have upgraded to Standard Edition 6.18.01. I was encountering issues seeing all the 435 modules in the Standard Edition so I uninstalled both versions and removed the ST Edition license assignment in my account.
After reinstalling Standard Edition I have access to 435 modules and have successfully run a simple design on my STM32F746-Discovery board using one of the modules that is not in the ST Edition. However, something then happens that changes the number of modules available back to 253 which is similar to the number in the ST Edition and I lose all of the modules in the Standard Edition.
When the Standard edition starts up I see '435 [modules] found' above the module list but after it loads the default 'NewSystem.awd' module the number of modules found changes to 253.
I cannot work out what is causing this but I assume it is linked to the fact that I used to have ST Edition installed. Please help!
Simon.
2:29pm
Hi Simon,
Are you connected to an ST target when you run the Standard edition and you see fewer modules than expected? If so, then it's likely that the modules aren't available on your target, even though they are available in the Standard edition of Designer. This would mean that your target's AWECore libraries don't include all the modules - for example, you may not have the advanced.a library built onto your target.
To confirm this, go to File->Global Properties and make sure that the 'Filter modules by target' box is unchecked. Now when you connect to Native or your ST target, all of the modules should show up in your browser, though the modules not available on your target will show up in red if you drag them out to your layout.
If your interested in getting the full set of modules for the ST target, please contact info@dspconcepts.com.
Let me know if I'm not on the right track with this answer.
5:00pm
Hi Axel
you are quite correct.
Simon.
9:00am
Hi Axel,
The Advanced AweCore library is compatible with AweDesigner STMicro, or we must buy the AweDesigner standard edition with advanced library, too?
Are there any information about advanced library on your website? We need mainly Single-Channel Noise Reduction module, and possibly the beamformer with AEC functionality.
11:30am
You will need the Advanced and Voice module libraries available on your target hardware to run a design that uses these modules. To access the Advanced or Voice modules, please contact info@dspconcepts.com for more information.
Hope this helps
3:25am
Thanks for the information.
