When using custom window coefficients in the "window" block, the coefficients is not retained when opening the project again. It's set back to default rect window. Is there a way to retain the coefficients?
9:44am
Hello! Currently there is no way to retain the coefficients in this module, but we are working on a fix for future releases of Designer. In the meantime, reloading the coeffs from a .csv is the best way to go.
Andrew P
