I'm trying to set up a 4way xover with 2 different slopes, Parametric EQ and some coefficients. I know coefficients very from DSP manufactures, But i can measure the results and compare them to my miniDSP. I have all the information. I'm very new to audio weaver. Help would be much appreciated!!
Joe
3:41pm
Hello Joe,
I believe you may be able to accomplish your design with the "Biquad" and "Second Order Filter Cascade" modules. In the Biquad module you can input coefficients by right clicking on the module and selecting "View Properties". In the module's properties tab, you can also set the number of stages in the filter.
In the Second Order Filter Cascade module, if you double click on the module the inspector window will pop up. Here, you can select the filter type at the bottom of the window, and adjust the frequency and Q as needed. Hopefully this helps, but if not please feel free to elaborate.
