I've just started using AW using the windows server as my audio target (no physical DSP at the moment). I can successfully use the built-in player, but I'm wondering if it's possible to use 3rd party audio players as a source? Any way to play music from something like Apple Music or Audacity, but pipe the output into AW for processing?
11:30am
Hi John,
This is possible. One way would be to write your own code (Windows BSP/App) to write the audio buffers from Apple Music (or the audio app of your choice), to the Windows BSP/App, and have Audio Weaver to read from there. We have documentation and examples of how to do this here: http://download.dspconcepts.com/awecore/index.html.
Another option would be to use an existing virtual audio bussing program. I'm hesitant to guide you to 3rd party software, so I'm not recommending you use this option, but I personally use a program called Virtual Audio Cables (https://vac.muzychenko.net/en/). It shows up as a sound card for your audio devices, and you can send and receive audio between applications on your computer. It will show up in Audacity as an input/output sound device as well (screenshot attached). To use this with Audio Weaver, from the Audio Weaver Server, you would go to 'File > Preferences', and select it as your input/output Audio Device (screenshot attached).
The last option, would be to just use the 3.5mm line-in on your pc and stream music from an external device (e.g. cell phone) to Audio Weaver. To do this, you would adjust your input/output devices from the Audio Weaver Server Preferences accordingly as described above, and then in Audio Weaver Designer, go to 'Layout > Layout Properties', and switch the PC/Linux Audio Source from 'File' to 'Line Input' (screenshot attached).
Hope this helps!
