Hello, There are two pop up menus that go off screen and I am unable to click them or interact with them in any way.
The first one comes at the start up of audio weaver...there is an "ok" menu which I need to click in order for the program to start. Without pressing ok I cannot start the program, but luckily I can press enter and the issues goes away.
the second one comes when I right click a filter block and try to plot the response. the response goes somewhere off my monitor screen and I cannot view it or interact with it.
I am using multi-monitor set up. Is there a way to resolve this? can it be resolved in the next software release?
Gel
7:53am
Would you provide us the details of your monitor setup. What is the screen resolution in pixels of each monitor and what scaling is being used for each? Are you running the Standard or Pro version of our product?
For now is it possible to use ALT-TAB to find the pop-up and interact with it?
12:09pm
here are my monitors
the resolution is the following
1 - 3240x2160
2 - 2560 x1440
3 - 1440x 2560
I am running standard. Alt+tab doesn't work for some reason as it doesn't show up on the menu or the task bar.
