I have a brand new STM32F407 Discovery board. I have installed Audio Weaver Designer 6.18.02 STMicro.exe.
I have connected up the Discovery board with the USB cable to my PC.
Then I proceed to use Audio Weaver Server --> Target --> Change Connection --> USB (VID: 1155/PID:407) --> Click Change...
A window dialog popped up showing "Unable to create USB port - is this port in use by another program?"
I tried with another PC and changing to a new Discovery board, repeated the installation and I got the same error.
What else can I do? I really don't think the USB port is used by any program at all.
Please help!!!
Regards
Lam KL
1:34pm
Hi Lam,
It's not clear from your post, so just checking. Did you flash the Discovery board with a .bin image from the downloadable BSP?
You may also want to try a different USB cable, since users sometimes have issues caused by certain cables. This thread may also have some other ideas to fix your problem: https://dspconcepts.com/forums/audio-weaver-general/440-stm32f7-discover...
Hope this helps.
1:38am
I have an STM32F769i- Discovery Board. I have Flashed the Board with the .bin file downloadable from DSP concepts, using STLink Utility. In the Audio Weaver Server, I am getting the error of "Unable to create USB port - is this port in use by another program?"
I have tried different USB cables for USB storage support. I have tried restarting with PC also. I have checked the user manual, and the Sound Control of the PC is not showing "STM32 Audio Streaming in FS mode".
What should I do now?
Help!!
10:16am
Hello Vaibhav,
If flashed correctly, you'll see the F769 EVK device in your Windows Device Manager enumerate as pictured below:
Do you see this?
4:27pm
I'm having the same trouble as KL Lam. I have been using my board for years and did not previously have trouble with "Unable to create USB port - is this port in use by another program?" I know the board and cables are fine because I carried the whole lot to the lab down the hall and everything works as expected there. On my laptop in my office (where everything was also previously working), I have tried restarting my machine, reinstalling AWE Designer and reinstalling CortexM4. I flash the board each time before opening AWE Designer. My USB cables are connected directly to my PC, not to a hub. Do you have any additional thoughts for me?
12:49pm
News! News that might useful to others experiencing this error (including, but not limited to, my lab students). I had another (working) STM32 project in my C:\DSP Concepts\AWECore ST_EVAL_CortexM4 Release-8.D.2.3\SampleApps\STM32F407 directory. When I reinstalled AWE Core for Cortex M4, it did not reinstall over this directory. I moved the contents of my STM32F407 directory elsewhere and then reinstalled the AWE Core. After that I was able to Change Connection to USB port as before. I have not seen a reference to this method of solving the "unable to create USB port" problem. Hope the idea might be useful to others.
