AWE Designer
Topic / Topic starter Replies Last post
Normal topic ASR on AWE
by eric.zhang_5822 » Wed, 04/24/2024 - 3:44am
1
by Karishma
Thu, 04/25/2024 - 2:17pm
Normal topic It's impossible to change the gain via Param Set in GranularSynthesisWaveFFS.
by koike.ryoma001_12177 » Tue, 04/23/2024 - 2:46am
2
Wed, 04/24/2024 - 6:22pm
Normal topic Please teach me how to change the playback file in WaveFileSource or WaveLoopPlayerRAM and reflect its content in an awb file via TCP/IP.
by koike.ryoma001_12177 » Fri, 04/19/2024 - 2:38am
2
Mon, 04/22/2024 - 1:02am
Normal topic I want to use AWE Designer to handle parameters sent by other software.
by Koike » Tue, 04/02/2024 - 6:18am
6
by Koike
Wed, 04/10/2024 - 12:42am
Normal topic How to properly configure the PulseGen module
by naomichi_tsudun... » Thu, 03/28/2024 - 5:07am
4
Tue, 04/02/2024 - 1:17am
Normal topic target does not have all of the module classes need to build this system
by mhkwon_12451 » Fri, 03/29/2024 - 2:45am
3
by DSPC_Gary
Mon, 04/01/2024 - 11:03am
Normal topic About the module that handles strings
by naomichi_tsudun... » Thu, 03/21/2024 - 6:58am
4
by Karishma
Thu, 03/28/2024 - 7:12pm
Normal topic About Tuning Interface Test
by makotosudou » Wed, 03/13/2024 - 11:06pm
2
by makotosudou
Tue, 03/26/2024 - 10:33pm
Normal topic About System Variables Module
by makotosudou » Wed, 03/13/2024 - 10:57pm
4
by makotosudou
Tue, 03/26/2024 - 10:13pm
Normal topic How to debugging custom modules
by makotosudou » Tue, 03/19/2024 - 6:23am
3
by DSPC_Gary
Thu, 03/21/2024 - 9:44am
Normal topic Beamformer autodetect the signal direction
by eric.zhang_5822 » Tue, 03/19/2024 - 2:21am
1
by Karishma
Tue, 03/19/2024 - 2:06pm
Normal topic Login Failure, L004 Email or Password invalid
by Zhijun » Fri, 03/15/2024 - 9:32am
2
by Karishma
Mon, 03/18/2024 - 1:10pm
Normal topic How to Hide Edits in AWE Designer
by naomichi_tsudun... » Wed, 03/06/2024 - 2:09am
3
by DSPC Kevin
Mon, 03/18/2024 - 3:06am
Normal topic External control of module parameters via I2C or potentiometers
by tim_2639 » Fri, 07/13/2018 - 3:44pm
5
by Axel Nilsson
Fri, 03/15/2024 - 1:13pm
Normal topic How to use FFSStartAddr in the FFSWrapper module
by naomichi_tsudun... » Mon, 03/04/2024 - 2:38am
3
by Karishma
Wed, 03/13/2024 - 1:09pm
Normal topic How to delete input/output pins in Matlab Scripting
by noguchi.wataru0... » Mon, 03/11/2024 - 5:36am
4
Wed, 03/13/2024 - 3:55am
Normal topic How to classify in different learning models.
by sw-licensee » Mon, 02/19/2024 - 11:48pm
4
by sw-licensee
Tue, 03/12/2024 - 4:22am
Normal topic Airoha 1585 and 1565 EVKs are not working with awe designer
by Varsha » Tue, 03/05/2024 - 5:53am
2
by Varsha
Wed, 03/06/2024 - 4:19am
by Varsha » Tue, 03/05/2024 - 5:56am
by Varsha
Normal topic How to avoid CPU overflow when the target is native
by yanagi.shota_12181 » Wed, 02/21/2024 - 5:16am
3
by DSPC Kevin
Fri, 02/23/2024 - 12:01am
Normal topic Please provide the command to change the path of the fileName within WaveLoopPlayerRam via TCP/IP.
by koike.ryoma001_12177 » Thu, 02/15/2024 - 1:54am
1
by DSPC Michael
Thu, 02/15/2024 - 4:24pm
Normal topic AWE Designer 8.D.1.1 STMicro STM32F746G_Discovery.bin Missing
by fatih.yildirimh... » Thu, 03/02/2023 - 7:18am
7
by DSPC Kevin
Thu, 02/08/2024 - 7:36pm
Normal topic AWE is not started
by mhkwon_12451 » Mon, 01/29/2024 - 9:26pm
4
by DSPC Kevin
Wed, 01/31/2024 - 9:53am
Normal topic How to calculate the dot product of vectors and display Hidden Variables
by yanagi.shota_12181 » Wed, 01/24/2024 - 9:16pm
1
by DSPC Michael
Thu, 01/25/2024 - 12:10pm
Normal topic Could you please provide the commands for referencing and modifying parameters within Subsystem using TCP/IP in C# ?
by koike.ryoma001_12177 » Tue, 01/23/2024 - 10:28pm
2
Wed, 01/24/2024 - 5:44pm
New posts
No new posts
Hot topic with new posts
Hot topic without new posts
Sticky topic
Locked topic
